Project settings
WildLud
Project settings
Post by WildLud »
Hello, I'm puzzled with the Dimensions choice in the Project settings.
As it can be changed, what is the best way of working ? Keep with default HdTV settings during the creation and then switch to 4K UHD (same aspect ratio) just before rendering or should i start form the beginning using the final resolution i want to obtain ? My project will mix vectors and bitmaps and i will make the bitmaps 3840*2160 however
How do you work, Any advice to avoid me falling in a trap ?
Buy the way thank you all, it's a very nice and usefull community.
Ludovic.
Re: Project settings
I suggest to work in final output size, in your case 4K. Bitmaps are mapped 1:1 pixel during import, so you'll spot something which is too small immediately. Don't change project dimensions as long as you're importing more bitmaps!
Dimensions don't have any impact on performance during editing.
