New User Trying to get to grips animating in Moho
Ronintalk
Post by Ronintalk »
Hi Everyone
There are some wonderful animations here and I am always amazed and inspired by what can be made using Moho.
I have just began to use the software and I am mainly using it to produce animations for music video. The thing that lets me down at present is my knowledge of some very basic animation skill. I am a reasonable story teller and Moho gives me the ability to, let's say cheat my way through my lack of knowledge.
I hope to improve the more work I do. In the mean time here are a couple of animations showing my first efforts. All comments welcome, especially advice on how to improve a forward facing walk. Ronnie
Down to Earth by Ronnie Elliot
https://youtu.be/4rA0ymEcb6Y?si=h0pylmqSEAuaGgsl
Little Engine that Could song by Christine Sparks
https://youtu.be/DMqLFK64lgk?si=zexFZVRWEts-25cH
Re: New User Trying to get to grips animating in Moho
I like your style! Good choice of colours, good use of filters on found pictures. If your animation improves, this can lead to some really wonderful results.
Ronintalk
Post by Ronintalk »
Thanks slowtiger. much appreciated.
Little Yamori
Post by Little Yamori »
You're off to an EXCELLENT start. Great imagery and presentation. The Moon Man song was really very good. You have a good tone in your story telling, pulls in a strong sense of sad nostalgia.
Keep up the good work.
I would check out Poptoogi's youtube channel for all sorts of Moho tutorials. Not sure if there is a front walk cycle there, but here's one from NeetersGuy
Ronintalk
Post by Ronintalk »
Cheers! Little Yamori and thanks for the walk cycle info. That is much more fluid. :D
Mikes1025
Post by Mikes1025 »
I thought to add here my issue with cycle since I thought it's similar enough to the initial issue. When I try to cycle the bone translation of layer mentor I get this ticking movement instead of the smooth interpolated movement that I would get if I had left its keyframes alone. I have a sample of it in the file attached in the hyperlink. Will anyone advise?
https://drive.google.com/file/d/1-QQjqa ... sp=sharing
Update* my link was set to restricted. I have it set otherwise now for anyone to access.
