Position Control Bone Not Working
ineviTabLe
Post by ineviTabLe »
I've come across a problem when trying to follow this tutorial. When trying to use the Position Control Bone setting, for some reason the lower handle won't stop moving weirdly. I've tried making it at least three times on new files, so there must be something I'm doing wrong. Using Moho 14.
My attempt:
The tutorial:
Re: Position Control Bone Not Working
The bones are being controlled by the wrong axes, and one target bone looks like it's parented to another bone.
ineviTabLe
I figured out the issue, thanks for the help. It turns out I had the bones parented when none of them should have been parented.
For others who come across this, that means the parent bones' angles were changing which angle the controlled bone moved on.
ineviTabLe wrote: ↑Sat Jul 06, 2024 11:16 am It turns out I had the bones parented when none of them should have been parented.
Or, parent everything to a single master bone. This will let you move the setup within the project as necessary and between projects without breaking the parent-child relationships and angles.
