Moho14.2 font is not compatible with special symbols, displaying error blocks
Post by 570295535 »
As can be seen from the comparison in the picture, Moho 14.1 is displayed normally, but 14.2 cannot be displayed. I have tried many font replacements under C: \ Program Files \ Moho 14 \ Resources \ Fonts, but they cannot fix this issue.
Some special symbols:
I'm from China, currently using: Moho 15 » Win10 System
:D :D :D :D :D :D :D :D :D :D :D
lucasfranca
Re: Moho14.2 font is not compatible with special symbols, displaying error blocks
Post by lucasfranca »
Following here to find out how to resolve it.
Your script is very interesting. What he does?
https://youtube.com/animai2D
In order to allow the full use of different languages, Moho 14.2 had to get rid of special unicode characters.
Sadly, it's one or the other. Apparently they can't do both.
For scripts, you will now need to use image buttons.
SimplSam
Post by SimplSam »
You can get partial respite if you:
- Download GoNotoCurrent-Regular.ttf / GoNotoCurrent-Bold.ttf from: https://github.com/satbyy/go-noto-universal/releases/
- Rename them to: GoNotoKurrent-Regular.ttf / GoNotoKurrent-Bold.ttf
- Copy to: <Moho 14>\Resources\Fonts (after backup etc.) ** Caution - System Application Folder
- Restart Moho
The GoNotoCurrent font is without Korean Support and has partial coverage of Unicode Emoji Glyphs. i.e. Some are still missing, and some look different. What I am finding is most fonts don't appear to support many Emoji Glyphs directly, but rather rely on the app / OS to fallback to system emoji fonts when needed.
(using FontBase app. Text at bottom is input: "The quick ☰ 🗿🔒 ↔ 🖫 ▷ 📄🡄 🌀 ● ✓ brown fox")
Post by 570295535 »
SimplSam wrote: Fri Jul 05, 2024 12:22 pm You can get partial respite if you:
- Restart Moho
I have tried most of the so-called large character set fonts in the world, but they all lack some special symbols. In the end, I gave up and could only choose to give up using special symbols in scripts or go back to Moho14.1.
Google Noto,Adobe Source Han,MiSans,HarmonyOS Sans,OPPOSans3.0,AlibabaPuHuiTi-3,HONOR_Sans_1.0,SuperHan,WenJinMincho,全宋體,天珩全字库TH-Hak-4.0.0,遍黑体,simsun,KaiXinSong,Monu Last,Jigmo字雲,中华书局宋体字库,花園明朝HanaMin,全字庫宋體字型檔Fonts_Sung······
Post by 570295535 »
I later solved it myself.
I made a font that is compatible with my special symbols, implemented using [Microsoft YaHei UI]+[Segoe UI Symbol], and integrated 📄 and 🌀 Replaced with [Segoe UI Emoji].
Font download (蓝奏云):
https://xsz.lanzouq.com/isNGk23obgfc
Replace to the following address:
C:\Program Files\Moho 14\Resources\Fonts
SimplSam
Post by SimplSam »
Which tool did you use to edit the font/s?
I might have a play to get rid of that nasty Lock symbol in 'Noto Current' for my local system.
Hopefully, there will be a better solution in the future.
Post by 570295535 »
SimplSam wrote: Sun Jul 07, 2024 8:38 pm Which tool did you use to edit the font/s?
I am using the【Fontcreator】software. If the Lock symbol for 'Noto Current' you mentioned is a symbol in the font, it should be possible to replace it with this software.
