Physic and Liquid shapes does not work pretty well
Panha
Post by Panha »
Physic in Moho is a great tool. However, I think it needs to be improved. Look at the video here, I have a "ball layer" made up of "Liquid Shapes". Some shapes are hidden but Physics also calculate the hidden shapes and count them as shapes too.
[youtube]https://youtu.be/kMqIxcfsVzQ[/youtube]
Re: Physic and Liquid shapes does not work pretty well
The physics are working the way they're supposed to. Moho uses the curves in a layer, not the shapes, to calculate physics because that's what's physically there. Curves are the physical structure and Shapes are the 'skin' on the curves.
To make the ball bounce the way you want, use Weld Crossings and Delete Edge instead of Liquid Shapes. The result will look like this...
Tip: Sometimes I need to hold Alt to disable Smart Trimming for Delete Edge to work correctly and not alter the curves.
Panha
Post by Panha »
Greenlaw wrote: Sun Jun 30, 2024 11:05 pm The physics are working the way they're supposed to. Moho uses the curves in a layer, not the shapes, to calculate physics because that's what's physically there. Curves are the physical structure and Shapes are the 'skin' on the curves.
Thank you very much, It works.
Oh, I just thought of a fun trick you can try. If you make the ball pattern an image instead of vector art, and use Image Texture to apply it, you can slide the texture to make the ball look like it's rotating on a different axis from Z. This can make the animation look more dimensional, and the image texture won't change the shape of the ball.
Or...maybe not. Since there are no bones involved, I'm not sure what Image Texture will do in this situation. It should work, but let me know what happens if you try this. (I would try it myself, but it looks like a very busy day for me.) :D
Panha
Post by Panha »
Greenlaw wrote: Mon Jul 01, 2024 11:23 am Oh, I just thought of a fun trick you can try. If you make the ball pattern an image instead of vector art, and use Image Texture to apply it, you can slide the texture to make the ball look like it's rotating on a different axis from Z. This can make the animation look more dimensional, and the image texture won't change the shape of the ball.
Thank you, this is another useful tips. When free, I'll try the tip.😍
