Copy File
MehdiZangenehBar
Copy File
Post by MehdiZangenehBar »
How we can copy / move a file using script?
Re: Copy File
Generally, you can use os.rename to change the path of a file: https://www.gammon.com.au/scripts/doc.php?lua=os.rename
MehdiZangenehBar
Re: Copy File
synthsin75 wrote: Sat Jun 29, 2024 4:05 pm Generally, you can use os.rename to change the path of a file: https://www.gammon.com.au/scripts/doc.php?lua=os.rename
Thanks! what about copy? we can use cp command right?
Re: Copy File
You can either read a file and write it to a new one using the Lua IO library, or use whatever commands are available using os.execute.
The latter option would have to take into account different OS commands.
MehdiZangenehBar
Re: Copy File
synthsin75 wrote: Sun Jun 30, 2024 12:10 pm You can either read a file and write it to a new one using the Lua IO library, or use whatever commands are available using os.execute.
Got it, Thanks.
