I can't select certain points in my action
myleshilife
Post by myleshilife »
https://youtu.be/yb6xeLMiTHo
I can't seem to select certain points when im trying to edit my actions. It lets me edit at the start of the timeline but not the end. Everything on this layer is binded by points to either the arm or the forearm. Anybody know what I'm doing wrong here? 😅 sorry if i posted the video incorrectly ive forgotten the proper way to share video on a message board
Re: I can't select certain points in my action
Hi, welcome to the forum!
I see your Moho icon is the lighter orange, so I guess you are using Moho 13.5. In that version, when you have the camera animated in the main timeline, it can interfere with the screen position of the points in the actions timelines, even if they look like they didn't move. This problem was fixed in Moho 14, but you can still work your way arround it just disabling the camera animation channels in the main timeline. You will be able to select points normally in your actions timelines and then you can enable the camera channels again without losing any camera animation.
To disable an animation channel just click on the white dot that is on the right of the channel's icon. It will turn red if you disable it.
myleshilife
ahhhhh it works! i had ran into this issue a couple times and didnt kno why, you're a lifesaver! thank you so much.
