Target bone
Gakk42
Target bone
Post by Gakk42 »
I'm attempting to have this hand follow the target. I THOUGHT that it was supposed to just work without the target, as in, the forearm should follow the hand bone, but it's not working this way. So I made a target bone. Anyways, is there a way to have it not behave like a spaz? I think i would like it just to be connected to the forearm as in any other bone.
Any ideas?
https://youtu.be/FNbDvvokb0s
Re: Target bone
If you just want to pose the arm, use the Manipulate Bones tool. By default, this tool animates a bone chain using IK, so there is no need for a Bone target. Bonus tip: when you press and hold Alt, the Manipulate Bones tool switches to FK mode so you can pose the individual arm segments. For example...
A Target bone is best used for pinning the arm/hand to something, like a tabletop or the hips of the character. For example...
In the above example, I'm first using Manipulate Bones without Target bones to animate the arms freely. Then, I'm targeting the forearm bones--one to the Table Target bone, and the other to the Hip Target bone. Then I'm using Manipulate Bones to move the Torso Bones.
Sorry, these examples are a little sloppy, but they should illustrate the techniques accurately.
As for why the target in your example is acting spazzy: test it on a non-zero frame. Frame 0 is the Setup frame, and rig testing should always be done on an Animation frame. You can get away with testing a few basic things in frame 0, but not everything works there the way it works on an actual animation frame. You can use Toggle Frame Zero to jump back and forth. (Setting this to a shortcut is wise.)
Note: the blue guy example was tested on frame 0. I can tell because I see the Bone Strength capsules. In this case, I got away with it because this is pretty basic. To test anything more complex, I would have had to step into frame 1 or later.
Gakk42
Re: Target bone
Post by Gakk42 »
dude! Perfect!
The issue was that I always used transform, but manipulate is so much better! Thank you for that tip and your in depth answer :)
