how to show switch layer keyframes when i selected the master rig
peng
Post by peng »
I seems that i cannot show switch layer keyframes when i select the master rig bone layer. Is there a plugin that can allow me to show all the switch layer under the same rig when i select the master rig?
on a side note i think this can be improved in the next moho update.
thank you for your help in advance :)
Re: how to show switch layer keyframes when i selected the master rig
Just enable Timeline Visibility for the layer you want to keep visible. You can enable it for more than one layer if needed.
Timeline Visibility is the column with the watch icon.
peng
Post by peng »
thank you greenlaw, but there is a problem, that if its enabled, then the key frame will be forever visible on the timeline which is a bit distracting. just want to know if it can be treated like a normal keyframe which is only visible when the master layer is selected.
I don't think so, but, typically, I only enable Timeline Visibility when I need to sync an animation to the keyframes of another layer. When I don't need the keyframe reference, I disable the option.
Markers are another tool I use for keeping keyframes in sync.
