Keyboard - Mouse events not working
MehdiZangenehBar
Post by MehdiZangenehBar »
Except for the "OnKeyDown" in some cases (pressing f key), none of the following events works, why?
ScriptName = "Test_Script"
Test_Script = {}
function Test_Script:Name()
	return 'Test Script'
end
function Test_Script:Version()
	return '1.0'
end
function Test_Script:UILabel()
end
function Test_Script:Creator()
	return 'Test'
end
function Test_Script:Description()
	return 'Test'
end
-- Is Relevant / Is Enabled
function Test_Script:IsRelevant(moho)
	return true
end
function Test_Script:IsEnabled(moho)
	return true
end
-- Events
function Test_Script:OnMouseDown(moho, mouseEvent)
	print('Test_Script:OnMouseDown')
end
function Test_Script:OnMouseUp(moho, mouseEvent)
	print('Test_Script:OnMouseUp')
end
function Test_Script:OnKeyDown(moho, keyEvent)
	print('Test_Script:OnKeyDown')
end
function Test_Script:OnKeyUp(moho, keyEvent)
	print('Test_Script:OnKeyUp')
end
function Test_Script:OnInputDeviceEvent(moho, deviceEvent)
	print('Test_Script:OnInputDeviceEvent')
end
Re: Keyboard - Mouse events not working
Shortcut keys do not get passed to scripts.
OnKeyUp not working probably has something to do with the momentary tool selection (tool selected while you hold the shortcut, and then back to the last tool when you release it).
MehdiZangenehBar
So the only trigger is Alt?
