UI Alignments
MehdiZangenehBar
UI Alignments
Post by MehdiZangenehBar »
Is it possible to align any control to the right side of the toolbar? it seems LM.GUI.ALIGN_RIGHT dosn't effect at all.
Also is it possible to change width of the button? It seems this one is also missed.
ScriptName = "TestScript"
TestScript = {}
function TestScript:Name()
	return 'Name'
end
function TestScript:Version()
	return 'Version'
end
function TestScript:UILabel()
	return 'UILabel'
end
function TestScript:Creator()
	return 'Creator'
end
function TestScript:Description()
	return 'Description'
end
-- Is Relevant / Is Enabled
function TestScript:IsRelevant(moho)
	return true
end
function TestScript:IsEnabled(moho)
	return true
end
-- Events
function TestScript:OnMouseDown(moho, mouseEvent)
end
function TestScript:DoLayout(moho, layout)
	local button = LM.GUI.Button('Button', 0)
	layout:AddChild(button, LM.GUI.ALIGN_RIGHT, 0)
end
Re: UI Alignments
This works for my screen resolution, but if you change the size of the Moho window, you'd have to reselect the tool to update to the new window dimensions.
	layout:AddPadding(moho.view:Width() + 300)
end
It's really using the workspace view dimensions, because Moho doesn't natively report the window size to the API.
This example is resolution dependent, so to really make it useful, you'd need to query the OS about the screen resolution and window size.
Makes aligning to the right fairly impractical, unless you just want to align to the right side of the workspace.
You make buttons smaller using negative padding. If you want to see a master class in this technique, check out Rai's Shapes Window tool: viewtopic.php?t=36508
