Save/Load Preferences
MehdiZangenehBar
Post by MehdiZangenehBar »
I just implemented a simple save/load preferences functionality, but it seems dosn't work:
ScriptName = "TestScript"
TestScript = {}
function TestScript:Name()
	return 'Name'
end
function TestScript:Version()
	return 'Version'
end
function TestScript:UILabel()
	return 'UILabel'
end
function TestScript:Creator()
	return 'Creator'
end
function TestScript:Description()
	return 'Description'
end
-- Is Relevant / Is Enabled
function TestScript:IsRelevant(moho)
	return true
end
function TestScript:IsEnabled(moho)
	return true
end
-- Variables
TestScript.boolean1 = false
-- Prefs
function TestScript:LoadPrefs(prefs)
	self.boolean1 = prefs:GetBool("TestScript.boolean1", false)
end
function TestScript:SavePrefs(prefs)
	prefs:SetBool("TestScript.boolean1", self.boolean1)
end
function TestScript:ResetPrefs()
	self.boolean1 = false
end
-- Keyboard/Mouse Control
function TestScript:OnMouseDown(moho, mouseEvent)
end
-- Tool Panel Layout
TestScript.BOOLEAN_1 = MOHO.MSG_BASE
function TestScript:DoLayout(moho, layout)
	self.boolean1Checkbox = LM.GUI.CheckBox('Boolean 1', self.BOOLEAN_1)
	layout:AddChild(self.boolean1Checkbox, LM.GUI.ALIGN_LEFT, 0)
end
function TestScript:UpdateWidgets(moho)
	TestScript.boolean1Checkbox:SetValue(self.boolean1)
end
function TestScript:HandleMessage(moho, view, msg)
	if msg == self.BOOLEAN_1 then
		print('Message BOOLEAN_1 received')
	else
	end
end
KuzKuz
Re: Save/Load Preferences
Post by KuzKuz »
It appears you've used the script builder from https://mohoscripting.com/, but you forgot to assign the checkbox value to a variable in the HandleMessage function.
MehdiZangenehBar
You right, now works correctly, Thanks!
		TestScript.boolean1 = TestScript.boolean1Checkbox:Value()
	else
	end
end
