moho:UpdateUI()
MehdiZangenehBar
moho:UpdateUI()
Post by MehdiZangenehBar »
anyone knows why moho:UpdateUI() cause crash in dialog?
Re: moho:UpdateUI()
If memory serves, I think it's because it sets up an infinite loop with the dialog's update widgets function.
It's been quite a while since I've run into though.
MehdiZangenehBar
Re: moho:UpdateUI()
NO, just a simple example that shows the problem:
ScriptName = "TestScript"
TestScript = {}
function TestScript:Name()
	return 'Name'
end
function TestScript:Version()
	return 'Version'
end
function TestScript:UILabel()
	return 'UILabel'
end
function TestScript:Creator()
	return 'Creator'
end
function TestScript:Description()
	return 'Description'
end
-- Is Relevant / Is Enabled
function TestScript:IsRelevant(moho)
	return true
end
function TestScript:IsEnabled(moho)
	return true
end
-- Variables
local dialog_table = {}
-- Events
function TestScript:OnMouseDown(moho, mouseEvent)
end
function TestScript:DoLayout(moho, layout)
	dialog_table.moho = moho
	local dialog = LM.GUI.SimpleDialog('Dialog', dialog_table)
	local dialog_layout = dialog:GetLayout()
	local button = LM.GUI.Button('Update', MOHO.MSG_BASE)
	dialog_layout:AddChild(button, LM.GUI.ALIGN_FILL, 0)
	local popup = LM.GUI.PopupDialog('Popup', true, 0)
	popup:SetDialog(dialog)
	layout:AddChild(popup, LM.GUI.ALIGN_LEFT, 0)
end
function dialog_table:HandleMessage(msg)
	--self.moho:UpdateUI() -- cause crash
end
Re: moho:UpdateUI()
You can't call functions with self.moho outside of dolayout, as that only refers to the state of moho when the dialog is launched (there's no longer an actual object to be updated).
You need to use the script helper for dialog functions that don't take moho as an argument: https://mohoscripting.com/classes/ScriptInterfaceHelper
Try this instead:
	local helper = MOHO.ScriptInterfaceHelper:new_local()
	local moho = helper:MohoObject()
	helper:delete()
end
MehdiZangenehBar
Re: moho:UpdateUI()
brilliant! Thank You so much!
