quickly clean up external svg
Nicohk92
Post by Nicohk92 »
From time to time when importing a stock svg or eps, I can waste precious time trying to clean up bad curves. Even a simple shape with apparently no issue will refuse to fill for one reason or another, and I have to inspect point by point, it's really maddening.
Is there best practice when importing an external svg? Perhaps a script or existing tool to clean up bad curves?
Most often I think it's less time consuming redrawing from scratch.
Maestral
Re: quickly clean up external svg
Post by Maestral »
There were some scripts for Adobe Illustrator which were handy for preparing vectors prior to uploading to stock.
Although the current svg import is pretty good it might still be easier if you fix the vectors prior to importing into Moho.
