Is there an undo and redo button in moho?
Joory
Post by Joory »
Is there an undo and redo button in moho? If so, where can I find it?
Hoptoad
Re: Is there an undo and redo button in moho?
Post by Hoptoad »
There is no button, but you can use the top menu instead: EDIT > UNDO and EDIT > REDO.
or ctrl-z / ctrl-shift-Z to undo/ redo (those are defaults - can be changed in Edit / keyboard shortcuts if you're more used to ctrl-y to redo; but you'll need to change "select tracing image" too which is ctrl-y by default)
Joory
Post by Joory »
Okay thank you!
I put Undo and Redo buttons in my MQC panel for Moho...
I made this because I find it easier to click on a button when using a tablet computer (i.e., no keyboard,) but I like to use it with a mouse and a regular desktop too.
This version was updated for Moho 13.5, but it works fine for Moho 14.1. I hope to release an update with new buttons soon-ish.
Pierre Gombaud
Post by Pierre Gombaud »
I'm a bit late to the party but, Eugene Babich made a script to add Undo/Redo buttons: https://drive.google.com/file/d/1GlE4dx ... dzKyi/view
