Update UI
MehdiZangenehBar
Update UI
Post by MehdiZangenehBar »
is it possible to add item to the toolbar, outside DoLayout event? on UpdateWidget?
Re: Update UI
You have to get it to reevaluate the DoLayout function.
I do this in my switch icons script by jumping to/from frame zero.
MehdiZangenehBar
Re: Update UI
Are you sure changing frame to zero will trigger DoLayout?
ScriptName = "Test_Script"
Test_Script = {}
function Test_Script:Name()
	return 'Test Script'
end
function Test_Script:Version()
	return '1.0'
end
function Test_Script:UILabel()
end
function Test_Script:Creator()
	return 'Test'
end
function Test_Script:Description()
	return 'Test'
end
-- Is Relevant / Is Enabled
function Test_Script:IsRelevant(moho)
	print('IsRelevant')
	return true
end
function Test_Script:IsEnabled(moho)
	print('IsEnabled')
	return true
end
-- Events
function Test_Script:OnMouseDown(moho, mouseEvent)
	print('OnMouseDown')
end
function Test_Script:UpdateWidgets(moho)
	print('UpdateWidgets')
end
function Test_Script:HandleMessage(msg)
	print('HandleMessage')
end
function Test_Script:DoLayout(moho, layout)
	print('DoLayout')
	local simple_dialog = LM.GUI.SimpleDialog('', {})
	local popup_dialog = LM.GUI.PopupDialog('Test', true, 0)
	popup_dialog:SetDialog(simple_dialog)
	layout:AddChild(popup_dialog, LM.GUI.ALIGN_LEFT, 0)
end
MehdiZangenehBar
Re: Update UI
And I don't know where is your script.
Re: Update UI
Here's the script: viewtopic.php?t=34078
At line 596, in the HandleMessage function, I do this:
	if (msg == self.UPDATE or msg == self.ALT_UPDATE or msg == self.DELETE) then
		local frame = moho.frame
		if (frame == 0) then
			moho:SetCurFrame(1)
		else
			moho:SetCurFrame(0)
		end
		moho:SetCurFrame(frame)
	end
MehdiZangenehBar
Re: Update UI
I run your script and still changing layer selection will not update the UI.
However your solution works in updatewidgets for me. nice trick, thanks!
MehdiZangenehBar
Re: Update UI
I did some other test and realized your code dosn't work when we change from group to another group. So I mixed with the layer creation and deletion:
			local current_frame = moho.frame
			moho:SetCurFrame(0)
			local temp_layer = moho:CreateNewLayer(MOHO.LT_SWITCH, false)
			moho:SetCurFrame(1)
			moho:SetCurFrame(0)
			moho:DeleteLayer(temp_layer)
			moho:SetCurFrame(current_frame)
Re: Update UI
Yeah, I have a note in the code about group layer selections. I believe that problem was introduced in a later version of Moho, after I initially wrote the script.
I'll have to see about incorporating your layer creation hack.
Thanks.
MehdiZangenehBar
Re: Update UI
Yea, and I created a boolean flag to prevent dependency loop and prevent UpdateWidget- DoLayout events call himself multiple times.
Another improvement would be to check the layer type and create different layer type to force the update.
