DoLayout event
MehdiZangenehBar
DoLayout event
Post by MehdiZangenehBar »
Changing selected layer should fire DoLayout event in the tool script, right? But sometimes this is not happening, anyone knows why?
Re: DoLayout event
On layer changes, DoLayout only reevaluates if you change layer type, like from a vector layer to a group layer, etc..
MehdiZangenehBar
Re: DoLayout event
So only event we can use to realize the layer change is WidgetUpdate? any other trigger?
Re: DoLayout event
IsEnabled is triggered by every layer change, so you can also use that function.
MehdiZangenehBar
Re: DoLayout event
So we don't have any standard way of calling DoLayout function?
KuzKuz
Re: DoLayout event
Post by KuzKuz »
If I need to completely redraw the script panel from scratch, I use this code:
local drawingToolsNonZero = MOHO.MohoGlobals.DisableDrawingToolsNonZero
if not drawingToolsNonZero then
	MOHO.MohoGlobals.DisableDrawingToolsNonZero = true
end
local frame = moho.frame
if frame == 0 then
	moho:SetCurFrame(1)
	moho:SetCurFrame(0)
elseif frame ~= 0 then
	moho:SetCurFrame(0)
	moho:SetCurFrame(frame)
end
	MOHO.MohoGlobals.DisableDrawingToolsNonZero = drawingToolsNonZero
end
MehdiZangenehBar
Re: DoLayout event
Well, your code will not fire DoLayout function for me.
MehdiZangenehBar
Re: DoLayout event
This is a test case with your code, you can see which events will be fired:
ScriptName = "TestScript"
TestScript = {}
function TestScript:Name()
	return 'Name'
end
function TestScript:Version()
	return 'Version'
end
function TestScript:UILabel()
	return 'UILabel'
end
function TestScript:Creator()
	return 'Creator'
end
function TestScript:Description()
	return 'Description'
end
-- Is Relevant / Is Enabled
function TestScript:IsRelevant(moho)
	print('TestScript:IsRelevant')
	return true
end
function TestScript:IsEnabled(moho)
	print('TestScript:IsEnabled')
	return true
end
-- Variables
local dialog_table = {}
-- Events
function TestScript:OnMouseDown(moho, mouseEvent)
	print('TestScript:OnMouseDown')
end
function TestScript:DoLayout(moho, layout)
	print('TestScript:DoLayout')
	local dialog = LM.GUI.SimpleDialog('Dialog', dialog_table)
	local dialog_layout = dialog:GetLayout()
	local button = LM.GUI.Button('DoLayout', MOHO.MSG_BASE)
	dialog_layout:AddChild(button, LM.GUI.ALIGN_FILL, 0)
	local popup = LM.GUI.PopupDialog('Popup', true, 0)
	popup:SetDialog(dialog)
	layout:AddChild(popup, LM.GUI.ALIGN_LEFT, 0)
end
function TestScript:UpdateWidgets(moho)
	print('TestScript:UpdateWidgets')
end
function dialog_table:HandleMessage(msg)
	print('dialog_table:HandleMessage')
	local helper = MOHO.ScriptInterfaceHelper:new_local()
	local moho = helper:MohoObject()
	end
	if frame == 0 then
		moho:SetCurFrame(1)
		moho:SetCurFrame(0)
		moho:SetCurFrame(0)
	end
	end
	helper:delete()
end
There is no DoLayout.
KuzKuz
Re: DoLayout event
Post by KuzKuz »
-- Provide Moho with the name of this script object
ScriptName = "MR_TestScript"
MR_TestScript = {}
function MR_TestScript:Name()
	return 'MR Test Script'
end
function MR_TestScript:Version()
	return '1.0'
end
function MR_TestScript:UILabel()
end
function MR_TestScript:Creator()
	return 'Eugene Babich'
end
function MR_TestScript:Description()
	return ''
end
function MR_TestScript:IsRelevant(moho)
	return true
end
function MR_TestScript:IsEnabled(moho)
	return true
end
-- Keyboard/Mouse Control
function MR_TestScript:OnMouseDown(moho, mouseEvent)
end
function MR_TestScript:OnMouseMoved(moho, mouseEvent)
end
function MR_TestScript:OnMouseUp(moho, mouseEvent)
end
function MR_TestScript:OnKeyUp(moho, keyEvent)
end
-- Tool Panel Layout
MR_TestScript.optionalButton = true
MR_TestScript.REDRAW_LAYOUT = MOHO.MSG_BASE
MR_TestScript.OPTIONAL_BUTTON = MOHO.MSG_BASE + 1
function MR_TestScript:DoLayout(moho, layout)
	self.redrawLayoutButton = LM.GUI.Button('Redraw Layout', self.REDRAW_LAYOUT)
	layout:AddChild(self.redrawLayoutButton, LM.GUI.ALIGN_LEFT, 0)
	if self.optionalButton then
		self.optionalButtonButton = LM.GUI.Button('Optional Button', self.OPTIONAL_BUTTON)
		layout:AddChild(self.optionalButtonButton, LM.GUI.ALIGN_LEFT, 0)
	end
end
function MR_TestScript:HandleMessage(moho, view, msg)
	if msg == self.REDRAW_LAYOUT then
		self.optionalButton = not self.optionalButton
		end
		if frame == 0 then
			moho:SetCurFrame(1)
			moho:SetCurFrame(0)
			moho:SetCurFrame(0)
		end
		end
	elseif msg == self.OPTIONAL_BUTTON then
	end
end
MehdiZangenehBar
Re: DoLayout event
Your code actually works, except for group layer, so I changed the code to support that as well.
Note that I added some flag to prevent fire UpdateWidget and DoLayout couple times.
Please have a look:
TestScript = {}
	return 'Name'
end
	return 'Version'
end
	return 'UILabel'
end
	return 'Creator'
end
end
	return true
end
	return true
end
-- Variables
local suspend_update_widgets = false
local suspend_do_layout = false
-- Events
end
	if suspend_do_layout == true then return end
end
	if suspend_update_widgets == true then return end
end
	suspend_update_widgets = true
	suspend_do_layout = true
	end
	local temp_layer = nil
	if moho.layer:LayerType() == MOHO.LT_GROUP then temp_layer = moho:CreateNewLayer(MOHO.LT_UNKNOWN, false) end
	if frame == 0 then
		moho:SetCurFrame(1)
		if temp_layer == nil then suspend_do_layout = false end
		moho:SetCurFrame(0)
		moho:SetCurFrame(0)
	end
	if temp_layer ~= nil then moho:DeleteLayer(temp_layer) end
	end
	helper:delete()
end
KuzKuz
Re: DoLayout event
Post by KuzKuz »
I don't recommend creating and deleting a layer just to redraw the panel. When you create or delete a layer, you store the entire project in memory for Undo and Redo purposes, even if you don't use PrepUndo().
Each panel update like this will cost you approximately 15-20 megabytes of RAM depending on the size of your project.
It would be better to find the first vector or bone layer, switch to it, refresh the panel, and then return to the layer you were on.
MehdiZangenehBar
Re: DoLayout event
So we should iterate over document layers and check the layer type? (find the first?) any example?
Re: DoLayout event
MehdiZangenehBar
Re: DoLayout event
synthsin75 wrote: Mon May 06, 2024 3:27 pm https://mohoscripting.com/snippets/1
I don't want to iterate over ALL layers, I need a function to find first match and exit the loop.
MehdiZangenehBar
Re: DoLayout event
KuzKuz wrote: Mon May 06, 2024 12:57 pm Each panel update like this will cost you approximately 15-20 megabytes of RAM depending on the size of your project.
Are you sure it took that amount of memory? Any function to calculate that?
