adding an outline in Moho 5
DK
Post by DK »
What is the correct way add just an outline to a shape in Moho 5
now that the old outline tool has changed?
D.K
DK
Post by DK »
This must sound stupid....but i'm stumped...i actually just want to draw a simple line with no fill????? How do i do this in Moho5???
D.K
kdiddy13
Post by kdiddy13 »
With the create shape tool, select your shape, press the space bar. In the style window, uncheck outline or fill. This should create the shape you want.
________
Design Host
DK
Post by DK »
Thanks for the rsponse but it's not a shape outline i want to make....it's just a simple unjoined line that i want to create from points?
D.K
7feet
Post by 7feet »
2 ways. One is to set you're defaults in the style panel, and then fill the checkbox for Auto Outline if you are drawing using the Freehand tool.
The other is to select the Create Shape tool, select the points you want to outline, and when you hit the spacebar you'll assign you're default settings to the line
If you need more specific info, give a yell.
--Brian
DK
Post by DK »
Hey thanks Brian.....for some reason i was using the shape fill tool and spacebar but nothing was happening....i just managed to do it then by starting up a new Moho file....thanks for the replies :)
D.K
