tiled image vectors do not like image layers in 3d mode.
jeremiahbabers
Post by jeremiahbabers »
im having this problem with tiled vectors in 3d view, it keeps crashing when using layer selector but only when an image layer is present
you can try it your self in a blank document,
1. insert an image
2. insert a vector with tiled image texture(tiled),
3. use camera rotation or workspace rotation
4. select any layer with layer selector
and congratulations, youve just crash moho.
SuperSGL
Re: tiled image vectors do not like image layers in 3d mode.
Post by SuperSGL »
I get the same thing. Will work fine with normal vectors even tried tex fill on both that still worked. but your version crashed. Even an image layer and a normal filled object crashes!
Norman McLaren
My Animations
SuperSGL
Post by SuperSGL »
I added effects like shaded and soft edge with Image that's what crashed If I take off the effects on the vector shapes it doesn't crash.
I started with 2 shapes on seperate layers and an Image layer. If the shapes have effects applied to them it crashes with select layers. without the image it doesn't crash. With no effects on the vector shapes and an Img it doesn't crash
Norman McLaren
My Animations
jeremiahbabers
SuperSGL wrote: Wed Apr 03, 2024 4:43 pm I added effects like shaded and soft edge with Image that's what crashed If I take off the effects on the vector shapes it doesn't crash.
i also added a shape in each layer, then added a new image layer. after applying the effects to each shape, i couldnt recreate the crash. am i doing something wrong here?
jeremiahbabers
anyone has a fix for this?
Seems to be working here:
I'm running 14.1 in Win 11.
Can you post the file that's crashing? I'm wondering if the image file in your project is the problem.
Here's my project if you'd like to try it.
tiledStarKitten.zip
jeremiahbabers
Greenlaw wrote: Wed Apr 03, 2024 8:21 pm Seems to be working here:
you dont have an image layer in the project. thats why theres no issue on your end
also, it should crash with any image
I missed that you added a second effect, so I tried that. Here's the same project with Soft Edge applied on top of Image Texture. Still no crash.
jeremiahbabers wrote: Wed Apr 03, 2024 11:31 pm you dont have an image layer in the project. thats why theres no issue on your end
Ah, ok...let me try that.
Here it is with an image layer. I tried selecting each layer, and it's still okay here.
I'll play with it a little more and see if I can make it crash.
jeremiahbabers
Greenlaw wrote: Wed Apr 03, 2024 11:40 pm Here it is with an image layer. I tried selecting each layer, and it's still okay here.
this is how i made it crash
video
https://imgur.com/ALklKkB
Last edited by jeremiahbabers on Wed Apr 03, 2024 11:46 pm, edited 1 time in total.
Nope...I tried a bunch of things, and it's pretty stable.
I even tried using the Select Layer tool. I normally don't bother with this tool because I can select any layer by Alt+R-Clicking on the element in the Workspace, so I wondered if the issue was specifically with the tool. It is still not crashing, though.
I'm still wondering if the issue is specific to your project. Can you post an example that crashes?
jeremiahbabers
Greenlaw wrote: Wed Apr 03, 2024 11:46 pm
i shouldnt have to upload a file since i can recreate it from a new project
Last edited by jeremiahbabers on Wed Apr 03, 2024 11:50 pm, edited 1 time in total.
jeremiahbabers wrote: Wed Apr 03, 2024 11:47 pm
I mean an actual project file or at least the images you are using. Or does this happen with any images you use?
I just tried here again using different images, and still pretty stable here.
jeremiahbabers
Greenlaw wrote: Wed Apr 03, 2024 11:49 pm
its with any image i use. ive downloaded your project. inserted your cat image as a layer, then when i used layer selector in 3d veiw, it crashed(same goes for alt+right click)
