How to apply "bend layer" with image layer while following path?
Damon_lai
Post by Damon_lai »
I saw that "bend layer" can be applied to image layer while following path from the Kukulkan sample on this tutorial:
- <Webinar – Taking advantage of Moho’s powerful particle system with Víctor Paredes> (45:54)
- https://www.youtube.com/watch?v=4Rw8O9fHF78&t=3s
But I failed when trying it, and it only worked with vector layer. I also tried and failed applying it on switch layer with images child as it looked like in Kukulkan.
I'm working with Moho Pro 14.1.
Thanks!
Damon_lai
Re: How to apply "bend layer" with image layer while following path?
Post by Damon_lai »
Problem solved: Layer Settings >> Options: Rotate with path
