A easier way to reveal all the key frames set in a complex character
peng
Post by peng »
i always find shifting key frames very toublesome especually there are a lot of point aniamtion and switch layer key frames set on sub layers of a complex character. I have been using a plugin to review all the layers that have keyframes set but it still very troublesome becasue you have to check each layer in order to show the key frames on the timeline, and you have to un check them to make the key frames disappear.
If you know a easier way to do this? thank you in advance. :)
Lukas
Re: A easier way to reveal all the key frames set in a complex character
Post by Lukas »
Are you currently using LK_ToggleKeysFilter per chance?
By adding two lines it would show all filtered layers on timeline:
	layer:SetShownOnTimeline(true)
Of course with multiple characters this is not a great solution. I've got the code for that too somewhere, but don't have the time to dig it up atm.
Adding the two lines like this:
-- *** ALTERED VERSION ***
-- See: https://www.lostmarble.com/forum/viewtopic.php?t=36921
-- Provide Moho with the name of this script object
ScriptName = "LK_ToggleKeysFilter"
LK_ToggleKeysFilter = {}
function LK_ToggleKeysFilter:ColorizeIcon()
	return true
end
function LK_ToggleKeysFilter:Name()
	return "Toggle 'keys' filter"
end
function LK_ToggleKeysFilter:Version()
	return "0.2"
end
function LK_ToggleKeysFilter:IsBeginnerScript()
	return true
end
function LK_ToggleKeysFilter:Description()
	return "Toggle 'keys' filter in Layer Panel"
end
function LK_ToggleKeysFilter:Creator()
	return "Lukas Krepel"
end
function LK_ToggleKeysFilter:UILabel()
end
-- The guts of this script
function LK_ToggleKeysFilter:IsEnabled(moho)
	return true
end
function LK_ToggleKeysFilter:IsRelevant(moho)
	if MohoMode ~= nil then
		if not MohoMode.visibility then
			return false
		end
	end
	return true
end
function LK_ToggleKeysFilter:Run(moho)
	FO_Utilities:FilterTag(FO_Utilities.keysTag, false, moho)
	local layers = FO_Utilities:AllLayers(moho)
	if moho:LayersWindowGetSearchContextValue() == FO_Utilities.keysTag then
		for i = 1, #layers do
			local layer = layers[i]
			if FO_Utilities:LayerIsAnimated(moho, layer) then
				FO_Utilities:AddTag(FO_Utilities.keysTag, layer, moho)
			else
				FO_Utilities:RemoveTag(FO_Utilities.keysTag, layer, moho)
				layer:SetShownOnTimeline(false)
			end
		end
	else
		end
	end
end
Lukas wrote: Fri Mar 29, 2024 9:57 am Are you currently using LK_ToggleKeysFilter per chance?
	return true
end
end
	return "0.2"
end
	return true
end
end
end
end
	return true
end
			return false
		end
	end
	return true
end
			else
			end
		end
	else
		end
	end
end
Hi Lukas, sorry to dig up this ol' thread but i just wanted to ask, what line of code i would have to add to REMOVE all the Timeline Visibility again when switching the tags off :D
Basically with your addition it almost does what i want, it shows the stuff on the timeline automatically but when i press it again it keeps the little checkmarks of all the layers. Just thought i'd ask :D Thank you!
martin_mrt
Post by martin_mrt »
Hello there,
did you find a solution yet? Im about to do an animation with a lot of point animated parts so im very curious to optimize this workflow. :)
With this script tool by A. Evseeva, you can do many things, and one of them is to show all animated layers in the timeline.
https://mohoscripts.com/script/ae_keytools
To do that, use the buttons: V v X
V: shows all the animated layers in the timeline.
v: shows only those animated after frame 1
X: don't show any layer in the timeline
Some features of the tool may not work correctly because it is a little bit old, but those 3 buttons work perfectly, I use them all the time.
Yea i have the Keytool. It's nice and all but it requires two clicks instead of one OR instead of one shortcut to show me the stuff ;)
