https://drive.google.com/file/d/1qrViFf ... sp=sharing
Failed to parse JSON document
This is a lens file I'm working on. I can't open it using 14.1 or 13.5. Can you help me fix it? Thanks
Re: Failed to parse JSON document
That link says "You need access"
- hayasidist
the file itself is corrupt --- a .moho is "just" a .zip with a thumbnail (.jpg) and a plain text JSON (.mohoproj). None of the tools that open compressed files (such as .zip, .7z, ..) that I've tried will open it to allow me to inspect the contents.
Opening with notepad -- it looks as though the file is full of (about 2.5million) ascii x20 (space) characters!?
how far back is your last backup?
Yeah - Just a file full of nulls.
hayasidist wrote: ↑Thu Mar 21, 2024 4:26 am the file itself is corrupt --- a .moho is "just" a .zip with a thumbnail (.jpg) and a plain text JSON (.mohoproj). None of the tools that open compressed files (such as .zip, .7z, ..) that I've tried will open it to allow me to inspect the contents.
Probably you have already done it, but (assuming you have autosave active) have you checked the autosaved files folder just in case there is a backup of your file/s there? If I remember well, in v14 at least you can directly get there by an entry in Help menu. I've never suffered something like that, but it has saved me in other cases, so there it is just in case...
Rai López wrote: ↑Thu Mar 21, 2024 8:57 am Probably you have already done it, but (assuming you have autosave active) have you checked the autosaved files folder just in case there is a backup of your file/s there? If I remember well, in v14 at least you can directly get there by an entry in Help menu. I've never suffered something like that, but it has saved me in other cases, so there it is just in case...
You mentioned you last worked on the file months ago, and I'm wondering, were you using an older version for Moho at the time, and were these files stored in a cloud storage service like DropBox? I believe there was a problem with an older version of Moho, where a project file could get corrupted when saved to a DropBox directory. I only heard of this happening with DropBox, but I suppose it could have occurred with other cloud storage services too.
To be clear, the DropBox problem does not occur with the current version of Moho (14.1), but if you were working with that older version at the time, maybe the file was a victim of this bug? Just a thought.
Greenlaw wrote: ↑Thu Mar 21, 2024 5:38 pm You mentioned you last worked on the file months ago, and I'm wondering, were you using an older version for Moho at the time, and were these files stored in a cloud storage service like DropBox? I believe there was a problem with an older version of Moho, where a project file could get corrupted when saved to a DropBox directory. I only heard of this happening with DropBox, but I suppose it could have occurred with other cloud storage services too.
Glad to hear you got everything back!
Here is a little more info about the Dropbox problem for anyone concerned about it: Using Dropbox for file transfers was fine; the corruption occurred only when working out of a Dropbox folder.
But, as mentioned already, this issue is fixed in the current release of Moho.
