white line in between shapes
peng
Post by peng »
I always have this white line when i render the image with anti alias on. this is a arm with reference layer as the forearm.
is there a way to remove the white line?
https://drive.google.com/file/d/1Cwr9iH ... sp=sharing
Maestral
Re: white line in between shapes
Post by Maestral »
Most likely those are very close edges between 2 shapes.
The easiest way is to add a point on one edge and overlap the other one with it. If possible, making the points of the edge curved could also do the thing - just overlap one shape over the other.
peng
Post by peng »
thank you for the help
