how do i add a glow effect like this?
Bicknell1999
Post by Bicknell1999 »
iv been scratching my head on how to make a glow effect on moho im aiming for something very silmiar to this image any advice on how they do it? Image https://ibb.co/Qcc0q8D
jeremiahbabers
Re: how do i add a glow effect like this?
Post by jeremiahbabers »
you could add a shape layer behind the character then turn soft edges in the layers panel. to make it look even better. you could have the shape as a separate layer with blending modes enabled
Not an exact match but gives you the idea.
Multiple layers to help you see the shape breakdown.
face lines is Screen blend mode
flames is also Screen
mid glow is Overlay
others are Normal
The flames and mid glow all use Curve Profile
of course, there are many other ways to achieve the end result!
Lots of different ways to do this, however, they have one thing in common: you have the original layer, plus one or more FX layers over and under it. Usually I start with just duplicating the original, then layer blur it. Just play around a bit with blur and opacity settings and blend modes.
Bicknell1999
That is perfect example exactly what i want only just seen the reply! Im gonna try this tomorrow!
there have been a couple of requests for more info in this. So here's the file I created: https://www.mediafire.com/file/ehxm5ulr ... .moho/file
I think / hope it's self explanatory, but if not ...
