How to use Stroke Exposure to start at the point we want?
Hi, I rarely used the Stroke Exposure tool before. Today I created a new character and thought that the tool would be great to hide the stroke (animated hide and show the stroke). However, while I was using the Stroke Exposure tool, I noticed that I could not start to hide the stroke from my desired point. It starts to hide the stoke from some other points that I don't need. Is there any ways to start hide the stoke from my desired point?
Re: How to use Stroke Exposure to start at the point we want?
Stroke exposure starts with the first point created in the curve. While it's possible to reset the start point in a curve, it's easier to install and use this third-party tool by SimplSam...
https://mohoscripts.com/script/ss_curve_exposure
Update: See the next post for how to reset the start point manually.
I had to check how I used to manually reset the Stroke Exposure start point before SimplSam created his script. The trick is to delete an edge, and then reconnect the edge. Where you start the re-connection becomes the new start point for the stroke exposure.
Like this...
Pretty easy, but SimplSam's script is still easier.
Like this...
Thank you everyone for the answer. I tried using the script, however I don't see any different between the third party script and the default one. However, I just know that it works from the starter point. I have never noticed that each drawing should be thinking of starting point if I want to use stroke exposure tool. This is a new experience for me. I'll read the official document for me information. Thank you.
I hope that for the next and next update, we will have the ability to custom select the point where we want the stroke exposure to start. By deleting the edge, we have to refill the fill to make the shape back. I tried using the third party script, but I don't know why it work just like the default script.
What Greenlaw explained (and Jiyahana) works without a script and is very easy to implement, depending on the curve you may have to re adjust it but that's it. Don't forget using the Alt key reverses the stroke exposer
Norman McLaren
My Animations
Norman McLaren
My Animations
With the ss_curve_exposure (3rd party) script, you just need to Ctrl-click the new start point.Panha wrote: ↑Sat Mar 09, 2024 9:14 am I hope that for the next and next update, we will have the ability to custom select the point where we want the stroke exposure to start. By deleting the edge, we have to refill the fill to make the shape back. I tried using the third party script, but I don't know why it work just like the default script.
