3D room texture fix
Lae82
3D room texture fix
Post by Lae82 »
Solution:
Instead of using 1 large image texture use several textures for 3D objects imported to Moho.
In this case I use 1 texture for every room wall (2048x2048 or less) this works in Moho.
The link contains the entire project with Blender and Moho files.
Here is a room I made and the resolution looks much better now. It's definetly possible to get
good texture quality if you use several Blender materials for one mesh object with different textures linked to the materials.
Using only 1 large texture doesn't work since Moho scales down imported 3D textures.
Moho 3D room texture fix:
https://drive.google.com/file/d/1eFXOQh ... sp=sharing
