unwanted jittery brush stroke when rendered
Little Yamori
Post by Little Yamori »
Hello All,
I just drew up a character with fur. I have the shape fill and stroke the same color, with the stroke is using a brush ( CK Hairy Toon ). But when I render the brush stroke goes crazy jittery as if it had "noisy outline" checked off in the vector tab of the layer (which it doesn't).
I tried it as well on a new layer with a fill and stroke simple circle and the same result occurs upon rendering.
I like the way I finally got the fur to look, but this ruins it if I can't render without this unwanted movement
Any suggestions??
Thanks in advance
Re: unwanted jittery brush stroke when rendered
Try disabling line boil in the brush settings.
Also check "minimize frame to frame randomness" in the brush settings. This way, brushes will be spread differently only if the distance between two outline points becomes different between frames.
Little Yamori
slowtiger wrote: Thu Feb 22, 2024 12:58 am Also check "minimize frame to frame randomness" in the brush settings. This way, brushes will be spread differently only if the distance between two outline points becomes different between frames.
by synthsin75 » Wed Feb 21, 2024 9:12 pm Try disabling line boil in the brush settings.
Thank you both!!
I didn't see the disable option for the line boil in my brush settings ( Maybe because I'm still using AS 11.2 ? ) but I was able to check the "minimize frame to frame randomness" and it worked immediately.
Thanks again to you both for always helping out
