Curveture and Move
MehdiZangenehBar
Curveture and Move
Post by MehdiZangenehBar »
Can we move points using Curveture tool? only handles?
Re: Curveture and Move
Curvature lets you control the smoothness/sharpness of regular Moho points (non-Bezier) and adjust the handles for Bezier points. To adjust the position of points, you need to use the Transform Points tool. I use the hotkeys to switch between them: C for Curvature, T for Transform.
If you want to do it all using a single tool, I recommend using MR Curve.
MehdiZangenehBar
Yea the tool looks great and does what I am looking for. Thanks
Lae82
Post by Lae82 »
Tips:
1.
Select point(s)
2.
While in Transform points mode press and hold down "C" key and click and drag with left mouse button.
When your done release "C" key to go back to Transform point mode ("T").
Ctrl + P = Convert selected points curves to straight lines
Ctrl + M = Convert selected points straight lines to curves
