question: How to create disconnected stroke with minimum points
skk
Post by skk »
Hello. Please give me an advice!
I'm trying to make a model with disconnected stroke as you can see in the image below.
(It is only a reference and what I'm trying to make has a little bit more complicated shape)
Next image below is a moho model I created.
left image: added some points and thinner stroke width → but the stroke width gets thin towards the end point.
right image: added more points to adjust the width → It looks good but too many points
I want minimum points for the setup.
So if there is a good way, please teach me!
Thank you.
Maestral
Re: question: How to create disconnected stroke with minimum points
Post by Maestral »
Hi!
It looks like you're using the Line Width tool and since you're tinning the line, you need those extra points.
If you try the Hide Edge tool - you'll need just two points, where you want the path to be disconnected.
