Custom layer colors?
jeremiahbabers
Post by jeremiahbabers »
is it possible for custom colors in moho, or atleast a scripts for it?
i wish it was possible to change it to something like white
Re: Custom layer colors?
Unfortunately, I don't think this is possible.
The only thing I can think of is changing the UI from dark gray to white in the Appearances settings will make the Plain color look white, but this turns the entire Moho UI white. This isn't desirable and I don't think there's a way to limit what gets changed.
My biggest issue with the Layers Window colors is that it's difficult to read the gray text against the slightly darker gray background. In this case, I would like to make the text whiter, not the background. I know this palette choice is meant to show when a layer is inactive but I'd like to make a small adjustment for personal taste, and I'm probably not alone in that.
Note: when the UI color is set to white, the text becomes black so maybe this improves readability for some users. But the overall blinding white UI...gak!
In general, I'd like to see more options for tweaking the UI to improve readability and usability.
