Hi all
I have a couple of features I hope might already be hiding somewhere. If not any help would be greatly appreciated.
1.Is there a smart bone that can use two bones instead of one to activate its blendshape? For example, I would like to have both a head rotate and a head tilt when they're at their most extreme poses activate a corrective. This is so that they don't conflict and break the rig but I can't find any options for it. Would be super handy.
2.Is there a hotkey that selects the parent bone group in the layer panel? Often I am fiddling around with vectors and points and then want to go back to the bone layer to tinker with them but every time I have to scroll back up to the top of the layer panel. A quick way to do this would be great.
Smart bone that can use 2 bones. Hotkey for parent bone in Layer panel.
- Stef Armchair Prod
Re: Smart bone that can use 2 bones. Hotkey for parent bone in Layer panel.
for 1 (Smart Bone fixer): I don't think you can say if SB1 is here and SB2 is there then [Do This]. There is however a script to help ... see lucasfranca's answer below.
for 2 (Select Bone Layer): There is also a script: https://mohoscripts.com/script/am_select_bonelayer. I have it assigned to key shortcut: Shift ^ (which is logical for me).
Select parent bone layer shortcut in vanilla Moho would be greatly appreciated, i agree...
- hayasidist
Land of dreams: node-based editors for actions....
- lucasfranca
I think the script he’s looking for is A. Evseeva’s Mix smartbone: [url]https:///mohoscripts.com/script/ae_mix_smartbones[/url]SimplSam wrote: ↑Mon Jan 15, 2024 12:04 am for 1 (Smart Bone fixer): I don't think you can say if SB1 is here and SB2 is there then [Do This]. There is however a script https://mohoscripts.com/script/mr_transform_rig_tool which is designed (in part) to fix/adjust conflicting Smart Bone deformations.
It can define that Rig will behave somewhat when the A+B bone is triggered at its extremes.
https://youtube.com/animai2D
Yeah - sounds better.
Thanks everyone, really appreciate the help. Will be trying these out and reporting back.
