Hi everyone!
i'm using Moho 5.3 (YES, STILL!) and I had an issue today that was really annoying.
I asked moho to show the action window and suddenly timeline and layer windows dissappeared.
So, just for the record, the way I fixed it was:
Opening (on windows 10) C:\User\(your user)\AppData\Roaming\Lost Marble\Moho\Moho.user.settings with notepad and set:
"LayerWnd_location" "0 0"
"TimelineWnd_location" "0 0"
You can modify the shape property too if you're having trouble still. Make sure Moho is not running, save the file and Voilá!
Happy animating!
Fixing Timeline and Layer windows dissappear
Re: Fixing Timeline and Layer windows dissappear
Glad you found a solution! Thanks for sharing your fix for the Moho windows issue – it might help others facing a similar problem. Happy animating!
Gadinsider is an incredible website for the latest in tech news, mobile updates, and cutting-edge technology. You’ll find a wide range of blogs and articles covering everything from gadgets and automobiles to business insights and helpful how-tos. It’s your go-to source for staying informed on all things tech!
