This is for those who scratch their heads when image textures (png/jpeg) are black in
Moho after importing 3D objects made in Blender.
First:
Correct texture path for .mtl file
When you export .obj from blender it also creates
a .mtl file where texture path is stored.
The .mtl file must have correct path
to where the texture image (jpg/png) is located.
Don't use absolute paths for texture images = C:/User/Folder/etc...
Use relative paths = textures/img.jpg
Open the .mtl file in a text editor.
Second:
Edit the path after "map_Kd" to where the texture image is located:
Example path with no subfolder
for image texture "cm1.png":
Example path with subfolder called "textures" for
map_Kd textures/cm1.png
If everything is done correct your texture should appear in Moho if you import the 3D .obj file.
Third:
Setup 3d object in Moho.
import .obj into moho.
Go to layer settings and disable:
Edges: Sillhouettes/Materials/Creases
Remove backfacing: uncheck
Shading:
Use Toon or Smooth shading
Blender to Moho .obj import preserving textures
Re: Blender to Moho .obj import preserving textures
The default .mtl file can look like this when you open it in text editor:
# Blender 3.6.0 MTL File: 'doorbell.blend'
# www.blender.org
newmtl button
Ns 250.000000
Ka 1.000000 1.000000 1.000000
Ks 0.500000 0.500000 0.500000
Ke 0.000000 0.000000 0.000000
Ni 1.450000
d 1.000000
illum 2
map_Kd textures/button.png
newmtl doorbell
Ns 250.000000
Ni 1.450000
d 1.000000
illum 2
You need to check the path is correct after map_Kd
newmtl = the name of the material created in Blender
Note:
Always UV unwrap to create UV map in blender for the 3d object
before .obj export.
# www.blender.org
newmtl button
Ns 250.000000
Ni 1.450000
d 1.000000
illum 2
newmtl doorbell
Ns 250.000000
Ni 1.450000
d 1.000000
illum 2
Note:
before .obj export.
Thanks for sharing this tip! I'm currently not working with obj's but I'll bookmark it for when I do.
Adults should play more often
Same. Bookmarked for future reference.
Thank you so much for this tip! I've just spent over an hour trying to figure out why my .mtl import had a red cross through it after importing my object into Moho.
Cheers
D.K
Cheers
D.K
My store on Renderosity:
