I use Moho Pro 14 and everytime i try to export video with particles with source depth, particles flicker like crazy.
I use Mac Studio on macOS Ventura, v. 13.6
Files with issue are here: https://drive.google.com/drive/folders/ ... sp=sharing
Particles issue
Re: Particles issue
Try disabling multi-threaded rendering in the export window.
Re: Particles issue
Thank you for fast reply! I will try this on monday, first thing when i get back in studio. I hope it works. I persuaded my boss to buy Moho software, and now it doesn't perform like it should
Why do you think multi-threaded rendering would cause trouble?
Re: Particles issue
Particles have to be calculated "in order," and multi-threaded splits up the rendering task and could interfere with it.
Re: Particles issue
It worked! The speed of export was extremely slow, but particles were drawn correctly. Thank you for this advice, you saved my ass.
Re: Particles issue
Yeah, that's the trade off. Glad I could help.
Re: Particles issue
Turn depth to 0 in the particle settings if you don't need it if you are using bitmap and/or psd files. this reduces render time and fixes the flickering issue.
