Another preview issue to flag, if I may. (v4.1)
The issue seems to occur to objects in a mask layer.
The issue is that stroke objects do not display above filled shapes, regardless of whether you bring the stroke object to the top/front or send the filled object to the bottom/back.
However, the object order of the layer renders correctly, and displays correctly if moved outside the masked group.
Stroke preview issue
- ZeroAbility
