Rendering or masking problem
tiquangali
Hi! I'm new to Moho and i have a problem with rendering or masking, i am not sure. I have these weird borders (like these super tiny ones) around shapes when i use brushes for the stroke, doesn't matter which brush i use. These shapes are masked. Please let me know if there is a way to fix that. Thanks.
Re: Rendering or masking problem
Hmm....I don't see that here in Moho 14.1, display preview or rendered.
I tried a few different brush styles, and they all seemed to render correctly.
Which version of Moho are you using? Which OS? Just wondering because I have seen something like this in old versions of Moho.
Can you post an example project that shows this error? This will make it easier to troubleshoot. Otherwise, it's just a guessing game.
tiquangali
Sure, here is the example project. I got the same problem in that project as well. I use Moho 14.1, i just bought it yesterday. My Os is Windows 11.
https://drive.google.com/file/d/196hkgM ... sp=sharing
tiquangali
Oh btw i just found out that these lines appear only when i enable "exclude stroke" on the bottom layer of the mask group.
Using "Expand mask by one pixel" helps a lot, but if that's not good enough, you can always move a reference of the bottom layer to the top and remove its fill, instead of using exclude strokes.
tiquangali
Oh that does help! Thank you so much
