Curvature Tool Problem
MatyMartel
Post by MatyMartel »
I don't remember having to set up or change how the curvature tool functions, but in the latest update it seems to behave differently than in previous versions.
When I drag on a point using the curvature tool, it will only add a bezier handle in one direction. I have to click the point again to drag out the handle in the opposite direction. Is there a tool setting to make it work similar to previous versions, where if I drag the with the mouse on a point with the curvature tool it will create a bezier handle in both directions?
Re: Curvature Tool Problem
It's a bug with the Add Points tool. In certain usage, it creates Beziers on only one side of the point. For now, select the points and click the Smooth or Peak button, and that will reset the points so the Bezier handles can work properly.
The developer is aware of this behavior, so hopefully it will be fixed before too long. :)
