SVG not found
Badr Fadel
SVG not found
Post by Badr Fadel »
Hello, friends. I am trying to import an svg file, using file>Import>SVG file but Always tell me the file is not found?
I am using moho 14.1 and Affinity designer.
SimplSam
Re: SVG not found
Post by SimplSam »
You might get the diagnostics File Not Found error if the filename or path has non-english characters in the name. Try renaming the file/path to fix this.
Badr Fadel
Re: SVG not found
Hello friend, thank you for your advice and help.
I organized the file inside the Affinity Designer and changed the path name to english.
So everything worked well inside moho.
