Blend mode issue (14.1)
opeth
Post by opeth »
In the new version 14.1, blend mode does not work correctly on the screen momentarily. For example, when you use the Color tab in blend mode, I can't see the result instantly, but I can see it when I render. It was working fine in the first version. Could you please check (macbook m1 max 16)
Moho 14.2 MacBook Pro 16'2 M1 Max 32gb.
