Lost Scripts' Shapes Window (**New** BETA 4 PE+) for Moho 14.3+ Pro
Rai López
Post by Rai López »
Lost Scripts' Shapes Window BETA 4 (PE+) v0.4.2 for Moho 14.3 Pro ↴
  • Image
Release Notes
Public dot release of Lost Scripts' Shapes Window BETA 4 (Performance Editon +), with some new features/enhancements and bug fixes...
- New Features & Enhancements:
  • Consolidated RGB/HSV color model logic (now switchable by a button) and unified Recolor mode
  • Introduced a factor-based UI scaling system to adapt button and menu sizes to Windows/Moho font and display scaling
  • Main Menu content is now dynamic so entries can reflect state or change according to other settings
  • Style items now indicate usage in project with an asterisk (*)
  • Style-Based Selection: select shapes by the styles they use
  • Shape list shows if items have 1 (·), 2 (.) or both (:) applied styles
  • Point group reordering is now possible (by recreation) with "to top/bottom" support
  • Stacked shapes creation now possible, with due warnings and undo support
- Improvements:
  • Several UI size/position fixes and tweaks (Apply & HSB buttons, Infobar, menus, window width, cursors)
  • Some icons/symbols display now better thanks to the Zero-Width Joiner (ZWJ) character
  • Debug Mode and Beginner’s Mode refinements
- Bug Fixes:
  • Selection is preserved after point group creation/update
  • Copy Infobar now retrieves the full text (specially useful for copying UUIDs)
  • No widget should blink anymore on frame change; also fixed some enable/disable inconsistencies
  • Enter Style mode by pressing Mode button didn't select the <None> item
  • Fixed additional Infobar concat related errors
  • v0.4.2-beta4a: Hotfix for typo `LS` instead of `LM.ColorOps:Ls_SetRgb` that caused errors in environments without it
- Known Issues:
  • In rare cases, when multiple projects are open (especially duplicates with identical layer UUIDs?), the window may become unresponsive or “stuck” to a layer from another project until restarting Moho. This bug may not be specific to this version and is under investigation...
⚠ IMPORTANT: This is a BETA that inherits very deep changes to the script’s core. While it has been tested extensively, it may still be more unstable than usual. If you notice any unexpected behavior, please report it.
:arrow: DOWNLOAD: ls_shapes.zip BETA 4 PE+ [v0.4.2.20251011-2117] (Windows & Moho 14.3+ Pro ONLY)
For more details, go to the Script Release Page at GitHub or to the (UNDER CONSTRUCTION) Script's Webpage. For support or reporting an issue, you can use the mean you prefer, but the official/preferred way from now on (for better following) is by the Issues section of the script repository, if possible. As usual, take into account it's still BETA and there may be errors, so any feedback is always welcomed... Thanks!
Lost Scripts' Shapes Window BETA 4 (PE 🚀) v0.4.1 for Moho 14.3 Pro ↴
  • Image
Release Notes
Public dot release of Lost Scripts' Shapes Window BETA 4 (Performance Editon), with some new features/enhancements and bug fixes...
  • Performance overhaul -> The script now handles a much larger number of elements with ease, drastically reducing response times in common operations. Internal improvements in Shapes, Styles, and Groups management has been made to minimize unnecessary UI updates and calls.
  • Style Indicators -> Listed styles has now a visual indication of what they define: ◍ (fill), ◎ (line) or ◉ for both, and `·` (width) `,` (brush) or `;` for both. This helps to get better idea of what they do at a glance.
- Bug Fixes:
  • The Mode button no longer blinks upon window updates.
  • The Lower Shape button is now correctly disabled when the last selected item reaches the bottom (avoiding missordering)..
  • Fixed Infobar Lua Console error when selecting a non-vector layer in Style mode.
  • Fixed occasional crashes when pasting styles via reassignment by using now `CopyStyleProperties` instead.
  • Shape creation buttons were messed up after last MSG reordering due to pairing dependency that now is fixed
  • Plus some more other tweaks...
⚠ IMPORTANT: This is a BETA with very deep changes to the script’s core. While it has been tested extensively, it may be more unstable than usual. That's why it's marked as pre-release for now... If you notice any unexpected behavior, please report it.
📄 NOTE: Due to the internal refactor, in this case any previous installed version of the script (including its resources) will have to be removed manually.
:arrow: DOWNLOAD: ls_shapes.zip BETA 4 P.E. [v0.4.1.20250916-2345] (Windows & Moho 14.3+ Pro ONLY)
For more details, go to the Script Release Page at GitHub or to the (UNDER CONSTRUCTION) Script's Webpage. For support or reporting an issue, you can use the mean you prefer, but the official/preferred way from now on (for better following) is by the Issues section of the script repository, if possible. As usual, take into account it's still BETA (the last not performance-focused one) and there may be errors, so any feedback is always welcomed... Thanks!
Lost Scripts' Shapes Window BETA 4 (v4.0.0) for Moho 14.3 Pro ↴
  • Image
Release Notes
- New Features:
  • New (alt) Group Mode -> Hold down <alt> key while pressing the Switch Mode button for point group management.
  • Handier Point-Based selection -> Now it is a handy multi-choice button (one click to invoke, hold <alt> key to make it retain active as previously).
  • Animated Shape Order helper/indicator button -> Indicates if Animated Shape Order is ON and allows basic current keyframe managing.
  • Debug Mode (OFF by default) -> For better diagnostics upon crashes.
  • Copy/Paste buttons can now copy/paste color only -> For quick color-only modifications (also copies and pastes to/from clipboard).
  • Affects Alpha option under Tweak Menu -> For more control over copy/paste and Recoloring.
  • Integrated Quick Help kind of interactive dialog -> Just a quick way of travel around main features and get further information...
  • Improved (plus copiable) Infobar -> Well, just that.
  • Custom Swatches folder access -> Now the menu entry opens the folder
- Improvements/Changes:
  • Relocated (Re)Color controls out of the Swatch space.
  • Reintroduced Select Shape tool viewport interaction after Moho 14.3 changes.
  • Improved Shape Order and Combine Blend buttons.
  • Improved MSG system for, among other things, better undo management.
  • Introduced an incipient but more flexible constants system.
  • Re-enabled MakeShapeNameUnique behavior for multi-renaming.
  • Internal refactor: LS_Shapes_Window → LS_Shapes & ls_shapes_window → ls_shapes (⚠ see note below).
  • Misc stability improvements.
- Bug Fixes:
  • IMPORTANT:Fixed crash related to Pick functions and main window resizing.
  • The script is now crash-proof if no document is open (also important!).
  • Color Pickers no more generate extra undo steps.
  • Recolor works now with Switch/FBF layers.
  • Much more minor fixes and improvements...
:arrow: DOWNLOAD: ls_shapes.zip BETA 4 [v0.4.0.20250911-0226] (Windows & Moho 14.3+ Pro ONLY)
A few screen recordings:
  • The new Group Mode in action:
  • The reintroduced Select Shape tool viewport interaction after Moho 14.3 changes:
Lost Scripts' Shapes Window BETA 3 for Moho 14.1 Pro ↴
  • Image
Release Notes
- New Features:
  • New Modes/Helpers! -> Mainly focused on dealing with coloring. The new menu allow you direct interaction with Select Shape tool and, among others, provide new ways of recoloring thanks to Mike Kelley kindly allowed me to include his "mk_adjust_colors" functionalities :). Oh, and this could change, but to actually see these controls make sure you have a Swatch visible!
  • STYLE Mode -> It's fully functional now. There you can inspect, delete, create, modify (to a certain extent) or just get them handy for quick apply.
  • Some (Limited) Brushes Support -> I couldn't do it as I would have liked due to some unexpected limitations, but there it is even if it's only to allow to see if a shape has a brush applied...
  • Item Preview Improvements -> Fills are showed again, plus some issues having to do with this and keyframe deletion should have been solved as well.
  • Enter Key (FINALLY) Confirms Renaming -> I think I found a way that seems to allow it. Available, but still under observation, though... UPDATE: It seems the patch prevents you from entering special characters. Oh, well...
  • Swap Buttons -> For quick Fill/Stroke colors and Style 1/2 swapping.
  • Tool Palette's Button Allows Closing -> That way you can open the window, do your thing, and quickly close it if no further needed all by a shortcut (thanks Daxel for the request!). Of course, Show In "Tools" Palette option must be checked for the shortcut to work.
  • *More* Live/Scrollable (kind of) Swatches! (Under Development) -> Choose any of the factory swatch or create your own ones in Moho, if a Pose/Morph named "SLIDER" is found it will allow certain kind of (limited :roll:) interaction. Please, don't expect them to be very precise in terms of color theory either... they are more intended to provide a quick way of first rough coloring. The included factory swatches are placed under "Custom Content Folder\Scripts\ScriptResources\ls_shapes_window\Swatches", but PLEASE, is advisable you place your own ones (or copy it for reference) in "Custom Content Folder\Swatches" instead.
  • General Menu's "Beginner's Mode" Change -> It allows you now to disable certain tooltips that may be useful at the beginning but annoying in the end...
  • 🤔 And I think that's all? -> But there are of course other improvements, although not all the ones I would have liked to do...
  • And some screen recordings related to the new features and improvements. First one, the window can be now more interactive and precise. Click over a shape's fill to get the controls ready for modifying its fill, the same applies to stroke (if any) and shape effect's handles, which now can be adjusted numerically and, therefore, more precisely:
  • More direct Style picking and modification:
  • Recolor in action, concretely HSB (Hue, Saturation, Brightness) in this case, but there is also a RGB mode. Both, allows quick recoloring/randomization over all OR selected shapes in a layer, the idea is it can work over several layers as well, but for now:
  • Some of the new scrollable Swatches:
- Some Known Issues (Priority Ordered):
  • [v] Recolor (RGB) incorrectly handles the alpha value -> FIXED in v3.0.1
  • [v] Recolor (RGB/HSB) modes don't take into account strokes -> FIXED (as option) in v3.0.1
  • [x] Use enter to confirm remane fix prevents you from entering special characters, and it's also likely the cause of a weird caret and Backspace behavior -> TBC
  • [x] Swatch rectangle can appear blank upon opening? -> TBO
  • [x] Plus the still unsolved ones listed below -> And, probably, some new others that I'll be adding as they arise or come to mind...
:arrow: DOWNLOAD: ls_shapes.zip BETA 3 [v0.3.0.20240209-0054] (Windows & Moho 14.1+ Pro ONLY)
Please, as usual (until I have a better system for it, someday 🙄) don't hesitate to provide any feedback you could consider opportune or report any issue/s you may find here. It make use of lots of tricks that seems to work, on Windows at least, but one never know... Well, thanks!
Lost Scripts' Shapes Window (BETA 2/2.1) for Moho 14.1 Pro ↴
  • Image
Release Notes
- New "General Menu" options:
  • Open On Startup -> If checked, the window will appear upon opening the first document (intended to work in partnership with next option).
  • Show In "Tools" Palette (Experimental) -> Show/Hide the button in toolbar, so you have a chance of can save some space as more of these kind of windows arrive... If hidden, go to "Scripts -> Lost Scripts - Shapes Window" to open. It kind of cheats Moho, but works perfectly fine here; any issue, please report!
  • Use Large Buttons -> Just that, same buttons but with larger clickable area (with the advantage of increasing Swatches and shape preview area a little bit too).
- New Features:
  • Mode Switcher -> Allows to to switch between SHAPE and STYLE mode (where you can now do basic style management) at any time.
  • Item Preview (Under Development) -> The currently selected shape is showed here for more quick/direct selection feedback.
  • Multi-Renaming -> You can quickly rename more than one shape (or style) at a time (thanks to Maarten's request).
  • Shape Visibility Button -> Gives you individual control over hidden shapes, which will be marked with an * in palette.
  • Checker Selection -> Does the same than Style Window checkbox.
  • "Style 1" & "Style 2" Selectors -> Does the same than Style Window ones.
  • Live (kind of) Swatches! (Under Development) -> Choose any of the factory swatch or create your own ones in Moho, if a Pose/Morph named "SLIDER" is found it will allow certain kind of (limited :roll:) interaction. Please, don't expect them to be very precise in terms of color theory either... they are more intended to provide a quick way of first rough coloring. The included factory swatches are placed under "Custom Content Folder\Scripts\ScriptResources\ls_shapes_window\Swatches", but PLEASE, is advisable you place your own ones (or copy it for reference) in "Custom Content Folder\Swatches" instead.
  • New UI -> The script has now its own resources, so everything looks more homogeneous and fitted.
  • Plus -> Much more improvements and additions...
  • And a screen recording of the window in action and the suggested swatches (though colors don't looks great in GIFs) usage and possible types:
  • [x] The window always opens/reopens at the center of the screen -> WON'T FIX (Moho's API limitation)
  • [x] Swatches' slider shows slightly offset respect to cursor while dragging -> TBC
  • [x] Custom Swatches and Use Selection entries does nothing for now... -> TODO/TBC
  • [v] Style creation is not yet possible -> DONE in v3.0
  • [v] Paste button stopped working as expected at some point -> FIXED in v0.2.1
  • [v] Open at Startup and window size problem -> FIXED in v0.2.1 (Kinda dirtily, but enough for now?)
  • [v] If open by Open at Startup, there may be then unwanted beeps upon frame change until reopen -> FIXED in v0.2.1
  • [v] Freehand/Eraser "Alt+LMB" width resizing doesn't work as expected if Points-Based Selection option is checked -> FIXED (I think) in v0.2.1
  • [v] Delete key doesn't act over selected keyframes while the window is open -> FIXED in v0.2.1
  • [v] Swatch frame can appear empty if the window is open by Open at Startup -> FIXED in v0.2.2
  • [?] I'll go adding more of them as they arise or come to mind...
:arrow: DOWNLOAD: ls_shapes.zip BETA 2/2.1 [v0.2.1.20240106-1805] (Windows & Moho 14.1+ Pro ONLY)
Lost Scripts' Shapes Window (BETA) for Moho 14 ↴
Release Notes:
- Menu options (They could change, but as a quick reference of some of its current features):
  • Points-Based Selection (Experimental) -> It allows a more bidirectional interaction but it can affect performance... Basically if you select all the points that conforms a shape, the shape/s gets also selected, thus you can work with it in palette.
  • Ignore Non-Regular Vector Layers -> If checked, Mesh Warp kind of layers' shapes are ignored (Curver and Auto-triangulated Warp Mesh layers are always ignored anyway).
  • Link To Style Window -> Uncheck this can improve performance, but then Style window won't be in perfect sync with the Shapes Window...
  • Advanced (Create) -> Just Hide or Show shape creation related widgets if unneeded or for saving vertical space.
  • Half Dimensions -> If checked, the window will open arround half of current viewport height.
  • Show Infobar -> Infobar provides some info you may find useful while working with shapes, but uncheck it if you wanted to save some more vertical space...
- Main Features:
  • Well, the name should say it all, but...
  • The idea behind this project, apart from experimenting with all this Moho 14 new modeless windows possibilities, was mainly allow to know what's going on in vector layers at a glance, specially when "Liquid Shapes" (best feature ever :mrgreen:) comes into play. To probe a point:
Although I've ended up adding some more things and it has taken more time than expected, but there it is for anyone that want to give it a whirl. Please, take into account it's BETA (plus Windows only tested) and there may be issues, so install it at your own risk and all that... If you found one, please, let me know bellow and I'll be glad to look at it as soon as possible. That's the main reason to publish it like this for now, instead of maybe in a more "official" way, but it seems that what I had planed instead, involving the due repository with its bug tracker and such, is also going to take (much) more time than the expected...
The overall design of the window is what it is because, don't ask me why, I also wanted to test how far I could go by only using already installed Moho resources. Regarding performance, well I've tried to do my best, but I'm sure there is room for improvements on that area... Apart from that, I've ended up adding more and more buttons and features that I thought could come in handy, but for their icons (and with the little help of tooltips) they should be self-explanatory, or I hope so :roll:. Cheers!
:arrow: DOWNLOAD: ls_shapes.zip BETA [v0.1.0.20231020-1717] (Windows & Moho 14 Pro ONLY)
P.S. Some more demonstration gifs...
  • Shape selection/creation no matter the active tool:
  • Switching projects, open, closing, etc. shouldn't be a problem:
  • And the different view modes:
Re: Lost Scripts' Shapes Window (BETA) for Moho 14
This looks fantastic Rai!
I can see this being very useful for more complicated Liquid Shapes setups (which I just happen to be getting into now.) :D
Will download and try it out this weekend.
Rai López
Post by Rai López »
Greenlaw wrote: ↑Fri Oct 20, 2023 10:57 am I can see this being very useful for more complicated Liquid Shapes setups (which I just happen to be getting into now.) :D
That's the (main) idea, Dennis! The more complex Liquid Shapes, the more useful it should be on that matter, plus (in my experience at least) as soon as you start getting used with this way of "see" shape ordering, the list's little Liquid marks, interactions and all that, the overall understanding of what's going on becomes very quick not having to go selecting or doing anything else. Of course, take care of go naming shapes also help... but that's something I've always liked (and advice) to do anyway.
Well thank you, I hope it works well (or as well as possible, taking into account there is a lot involved and I'm the only one having tested it till now 🙄), and let me know whatever you consider opportune!
Looks very interesting and super-useful
I've grabbed this release but it may be a week or so before I can get to it in earnest -- school vacation time here in (my corner of) the UK and so it's family week...
Wow, that looks amazing, Rai?
Awesome work!
Rai López wrote: ↑Fri Oct 20, 2023 11:19 am ...take care of go naming shapes also help... but that's something I've always liked (and advice) to do anyway.
I've always been good about naming Bones, Actions, and Styles in Moho, but I never bothered with naming Shapes. Looks like it's time to start doing this! :D
Thanks for the tip, Rai. I will let you know how your Shapes Window works for me.
Greenlaw wrote: ↑Fri Oct 20, 2023 1:25 pm I've always been good about naming Bones, Actions, and Styles in Moho, but I never bothered with naming Shapes. Looks like it's time to start doing this! :D
Just enable the preference to auto-name new shapes. Won't help on already existing shapes though.
Thanks for the tip! Will try it out.
Oh, I already have that enabled.
I guess I meant that I never give shapes a descriptive name like I do with Bones, Actions, etc. It's not normally necessary but I can see it being helpful with messy Liquid Shapes setups. :D
Rai López
Post by Rai López »
Yes, specially now with Liquid Shapes I consider descriptive names almost crucial, at least under more complex scenarios, since e.g. I found myself frequently unfolding the Style window's Shapes menu for consulting ordering when it was not clear by only looking at viewport That's one reason of why properly named shapes has been always important for me and I guess I just got used to it...
Well, thanks guys for the kind words! Lets see how it behaves under different setups and "pressure". I always hoped that if even in my old laptop it has kind of acceptable performance (with reasonable number of shapes at least), out there it only could work quicker, but even though... Of course, not everything is performance, and stability is one point I'd like to know more about, cause there are so much things to manage and take into account for the mere fact this windows can be always open, that you never know if you could have oversight something... But of course I hope not :roll:
SimplSam
Post by SimplSam »
That is a very Next-Level dialog. Tried it briefly on a Win & Mac and it appears to work as consistently on Mac as it does on Windows (with color icons).
I didn't initially get how to actuate the Options - as I was hitting the hamburger symbol in the title. Maybe the down arrow should be a hamburger instead, as the hamburger is also misplaced on the Mac.
I also like the whole "About" set of dialogs.
Mac
Acks
Rai López
Post by Rai López »
Woah! That's great to know, Sam! Thanks for your words too and for taking the time of testing it in both systems, sincerely I kind of expected UI issues (among others) not having had the opportunity of testing it on MacOS at all, but quite the contrary I think I kinda like it? I mean, those emojis looks cool and symbols seem to render quite better, plus, the LM_Divider doesn't seem to have any padding :o, just like I always have wanted they were! (Or at least it was optional).
A pity the little detail of the hamburger icon, tho... I put it precisely there because it served both as a window icon representing "stacked shapes" and the menu indicator just bellow, all taking the minimum space... I guess it was simply too good to be true and hence that horrible displacement :lol: (yikes!). But good to know, of course, since even if didn't I finally find a good enough solution, at least I can try to make it some pixels taller for MacOS, which hope somehow help...
SimplSam wrote: ↑Fri Oct 20, 2023 5:45 pm I also like the whole "About" set of dialogs.
Happy to hear that cause those kind of things is what I think I enjoy more coding after all, haha... Cheers!
Post by 570295535 »
:D I tried, and it was awesome, but it should remember the window coordinates before each close, so it can recover the next time it opens.
I'm from China, currently using: Moho 15 » Win10 System
:D :D :D :D :D :D :D :D :D :D :D
Rai López
Post by Rai López »
Thank you! And of course... But, sadly, there is no way to get control over dialogs positioning by means of Moho's scripting current capabilities, for now at least. So the only way I'm aware, I think thanks to a synthsin75 advice somewhere, would be by using some kind of external tool to somehow "interfere" upon opening/reopening and do the job like AutoHotkey, which with I've already done some achievements, but it has the inconvenient of not working as cleanly (or not as cleanly as I'd like at least 🙄) as a native way would do, as well as it definitely wouldn't work on MacOS. But I admit it's exiting when you get some results, so we'll see where this all ends up...
I just tried this today and wow. It's my favourite panel now. I just feel so much more in control with it open. It doesn't matter if I'm animating, ilustrating, rigging... I just love to have a clear picture of what shapes are in the layer, something so basic but so elemental to Moho. At the end Moho is basically a shape editor.
Hoping this inspires Moho devs to include it in the near future, as an optional part of the style panel or as an independent panel.
So far everything worked correctly except that after naming a shape, pressing enter doesn't confirm the editing (I can still select another shape and the editing will be confirmed). And the panel position memory that as I read is not possible yet (I hope Moho adds that soon too).
