For qualitative export of vector&bitmap from Moho in Fla
pasha e
Post by pasha e »
For qualitative export of vector objects from Moho in Flash it is necessary:
1. To create in Moho on one layer a minimum of objects. The more layers - the better.
2. To import in Flash separate layers
3. In Flash for the imported objects to do a command " Break Apart " is reduces a file swf
For qualitative export "bitmap" objects from Moho in Flash it is necessary:
1. After import of a picture in Moho to not change coordinate of object.
2. To create layers group, and to put there a picture. For each picture separate layers group
If it to not make - all pictures in Flash will lose the coordinates.
Here an example of translation Moho in Flash
http://www.aktush.com/ibm_02.html
