Hello!
I'm wondering if it's possible to export frames to psd files so that they contain not only layers, but also vector paths (the ones that the pen tool usually draws in Photoshop). This would be very convenient if you need to add raster effects and filters to the stroke or make a manual stroke with a raster brush with special settings, if for some reason the Moho brush settings are not enough... I know that you can simply select the layers and then convert the selection into a path, but sometimes it turns out angular and ugly...
Export PSD with paths (contours)
