How to fix keyframes in fix intervals on timeline
peng
Post by peng »
I am using moho14. I want the key frames to automatically snap in fix intervals on timeline. Is there a script that allows to do that. thank you in advance :)
Re: How to fix keyframes in fix intervals on timeline
I don't think there is a script for that. I'm not sure it can be done in a way that it is useful because: what should the script do if you are working on 2's at 24FPS and you create a keyframe at frame 23? automatically put it on frame 24 or frame 22? I guess it would only be able to help if you are working on odd numbers or you are working on 4's or 8's and you didn't put your keyframe in the middle, so it will never be too reliable if I understand correctly.
As you probably already know, we have the interval interpolation, and the interval markers. And I think there is a "next/previous keyframe" button that works with intervals so you can navigate the timeline at that interval. I'm not totally sure about the last one though.
peng
Post by peng »
got it, thank you for the info Daxel :)
