Image fill not showing when selected
It only seems to happen when the shape I'm adding an image texture to is in a group mask. I selected the bottom layer (select shape) which is set to 'don't mask this layer' And changed the fill to an image. While selected it wasn't showing up in the view port. If I select another object or just unselect it the image shows up. I have the handles to manipulate the texture but can't see it. This doesn't happen in 13.5. A regular group layer works as it should, as well as shapes on there own layers.
Norman McLaren
My Animations
Norman McLaren
My Animations
Re: Image fill not showing when selected
I did a test with just a normal group layer it was fine. Changed it to a mask layer the img.tex is on the bottom layer (of 3) that was fine. When I selected the bottom layer and changed it to 'Don't mask this layer' The image disappears in the view port. Selecting anything else brings it back. Of course it renders fine as well.
edit: Same thing happens when using the crayon effect
Norman McLaren
My Animations
Norman McLaren
My Animations
I concur. This has now been reported as an addition to an existing issue related to Style Effects and GPU Caching.
You may notice that if you disable GPU Caching, then the image texture of the shape on the do-not-mask layer will not display at all (shape, layer - selected/unselected).
