Hello!
I tried out the SVG import option and the first file (71 kB) worked OK, but the second (279 kB) strated OK, but then went into a loop of which it didn't come out in 15 minutes, so I closed the Moho. Similar results with other bigger files.
Is ther a size (or items) restriction for SVGs?
-Calle-
SVG - size restriction?
Re: SVG - size restriction?
There are no limits other than hardware. I have loaded SVGs over 2MB in size.
There may be something weird of complex about that file. You can PM me if you want me to have a look at it.
Hi SimplSam,
I have a question: Is the version of SS - SVG Import that comes with Moho 14 exactly the same as the one from MohoScripts.com?
If so, maybe it should be mentioned on the page that Moho 14 users do not need to install it. Just a thought.
Thanks for continuing to make cool tools for Moho!
Good point & done. The native Moho 14 version is superior as it has better support for Gradients etc.
Awesome! Thanks for the clarification!
Hello again,
I was too hasty. I made another try today and now it opened the bigger file after a short wait. Maybe there was a memory thing like you wrote, the first time. The only thing I changed was that I booted the system.
But anyhow. Thanks for your comments. Now on to work with the file.
-Calle-
-Calle-
