Moho v14 on Win10 64bit.
I noticed that when working with Liquid Shapes, anything using straight edges (particularly rectangles) distort slightly when a blend mode is assigned. Furthermore the shape directly below in the stack also distorts in a similar manner.
It doesn't appear to happen on curved shapes. I removed all custom scripts so this layout is as installed.
The distortion renders too. Can anyone else confirm this?
Liquid shape blend distortion
- EricTheFish
- concavepgons
Re: Liquid shape blend distortion
Yeah, I noticed this too. Hopefully it can get fixed soon.
- hayasidist
yep -- -- it seems to me that the stroke drawing logic in blended shapes "imagines" some extra points -- I tried this with a low-alpha stroke and it gave me some interesting "quadrants" at overlaps and the drawn stroke meanders across the path (i.e. the path is correct; the drawn stroke appears not to be) as in this:
the grey is the stroke -- black, low alpha; the thin red line is the actual drawing line (path) between the points; and the red circles are there (different layer) to highlight the "odd overlaps"
I've raised a report.
