Drawing tools
mihimal
Drawing tools
Post by mihimal »
Can I directly draw everything in Moho or will I need another software to draw like CorelDRAW?
Re: Drawing tools
Yes you can draw vector drawings inside Moho. You can draw adding points one by one using the Add points tool, or use the freehand tool to make vector drawings with a pen.
If you mean bitmap drawing, Moho doesn't have that option but it works really well with Krita, photoshop and other specialised bitmap drawing programs.
Re: Drawing tools
Moho has very powerful vector drawing tools including freehand lines, "paintbrush" for shapes; erasers (these three work in much the same way as a bitmap-based program); then there are tools to create a variety of "presets" and custom vector shapes.
Bottom line. NO you don't need an external drawing program.
BUT if you do have one, then Moho can import and use vector graphics such as SVG and bitmaps such as .png, .jpg and .psd
and mix the "native" vector with external images... we do it all the time. Just ask if you'd like to see some results.
(cross post - sorry Daxel)
mihimal
Re: Drawing tools
Post by mihimal »
Thanks for the reply sir. I only want to make Vector drawing, But are Vector Drawing Tools in Moho capable enough to make Detailed and Complex drawings like in CorelDRAW?
SimplSam
Re: Drawing tools
Post by SimplSam »
mihimal wrote: Fri Sep 15, 2023 7:07 am ... But are Vector Drawing Tools in Moho capable enough to make Detailed and Complex drawings like in CorelDRAW?
It is better for you to show us examples of the stuff you want to create then you will probably get even better advice.
Re: Drawing tools
Take a look at these. A side-by-side comparison of "bitmap" versus Moho (some WIP). All credit to Victor Paredes (Moho Product Manager) for the work in Moho.
https://discord.com/channels/1123979330 ... 8719205416
https://discord.com/channels/1123979330 ... 8558230528
IMO there is not too much need for bitmap drawing once you've got the hang of how to drive moho.
You can make complex shading and textures. You have various blend modes for combining layers...
Re: Drawing tools
mihimal wrote: Fri Sep 15, 2023 7:07 am Thanks for the reply sir. I only want to make Vector drawing, But are Vector Drawing Tools in Moho capable enough to make Detailed and Complex drawings like in CorelDRAW?
Yes. Moho has many features that can make vector drawings look like complex bitmap or even 3D images. I don't think there is an image that you can't achieve using these vector tools, even photorealism.
Here you have an example with the latest Moho 14:
https://www.youtube.com/watch?v=3yvZboj9mL8
But you should try it by yourself with the 30 days free trial of Moho 14 pro.
Re: Drawing tools
I use both bitmap images and vector drawings in Moho to create animations for our television productions. Oftentimes, I'll mix both types of art in a single character.
For examples of bitmap rigs, see The Croods, and All Hail King Julien on Netflix. Check out the Interactive Episode of Puss-In-Boots for an example of a hybrid rig. While working on Boss Baby, I used vector drawing almost exclusively in our rigs. The type of art I used was determined by the designs and animation style required by the TV show. (You can see some of this in my three most recent demo reels here: https://vimeo.com/channels/littlegreendog.)
For bitmap art, you'll want to use an external program that supports Layered PSD because Moho does not have bitmap tools. (Well, 13.0 briefly supported bitmap painting, but it didn't work very well and was removed in 13.5.5 when Lost Marble took over development.) Since version 13.5.5, Moho has gotten very smart about keeping track of layers, so you can change the art in the PSD, and it will update in Moho.
Back in Moho 12.5, I preferred to use PNG files, exported from Photoshop using the free Export Layers To Files Fast script. This tool batch exports layers to separate files, and has a ton of options not available with Photoshop's native exporter. But if you have Moho 14, it's practically unnecessary to use PNG files.
When using bitmap art, Moho has multiple advanced tools for deforming the artwork. As mentioned, you can seamlessly combine them with vector art too because you can fill and stroke vector art with bitmap elements. (Like in my Puss example.)
For vector art, I almost always use Moho's tools. Moho's vector tools are very good, especially in Moho 14. For art that needs to be precisely deformed using bones, you'll want to use Add Point, which got a nice upgrade in Moho 14. I used Add Point to create all of my Boss Baby rigs, and they animated perfectly!
If you use an earlier version of Moho, be sure to get Mult Rush's MR_Curve tool. (This tool was just updated to work in Moho 14 too!) You'll also want to get Hayasidist's HS_Shape tool...this is an advanced variation of the native Shape tool.
If want to use an external vector program with Moho, version 14 can import SVG and preserve most standard features of drawings. For Moho 13.5.5 and 12.5, be sure to use SimplSam's SS_SVG Import script. I used this for a lot of elements when I was the Lead Digital Animator on Fast & Furious: Spy Racers.
Re: Freehand and Blob Brush, these tools are Moho's freehand vector tools, and they work quite well in Moho 14. They can work okay in Moho 13.5.5 and earlier, but if you use a tablet, you need to make sure the Use Pen As Mouse option is disabled in Windows Pen And Ink control panel. (Disabling this is unnecessary for Moho 14...it just works!)
IMO, these tools are good for drawing elements that won't be deformed with bones and any items that you want to quickly draw for a Switch layer (faces, hand poses) or the Frame By Frame layer. They're less suited for bones because you usually want to carefully place your points to get the best deformation quality. That doesn't mean you can't use Freehand this way; it's just better to use Add Points if precision and getting nice definitions is critical.
