Moho Pro 14 issue
Cobra5005
Moho Pro 14 issue
Post by Cobra5005 »
I just upgraded to Moho pro 14 and i have this issue:
https://ibb.co/ysDV3dW
How i fix it?
Re: Moho Pro 14 issue
I'm not sure, but it looks like you have the Fills deactivated.
Try go to the bottom right corner of the canvas Display -> Fills
Or right click over the Dragon bone layer, Quick Settings -> Fills and Apply
Cobra5005
Post by Cobra5005 »
Nope it didn't work.
When i open Moho pro 13.5 it worked fine but not in Moho Pro 14 after i upgraded it
SimplSam
Post by SimplSam »
This could be an issue with your Graphics Card vs Moho 14. When I turn off Fills I see a different image to yours.
What is your Graphics card? Can you check to see if you have the latest Graphics drivers installed?
(My PC without Fills)
(Your PC)
Moho 14.3 » Win 11 Pro 64GB » NVIDIA GTX 1080ti 11GB
Moho 14.3 » Mac mini 2012 8GB » macOS 10.15 Catalina
Cobra5005
Post by Cobra5005 »
AMD Radeaon HD 7500 Series/7570
Cobra5005 wrote: Fri Sep 15, 2023 2:37 am AMD Radeaon HD 7500 Series/7570
That GPU is 11 years old, the latest drivers on AMD's site are for Windows XP, so that may be the problem. It may not be able to run OpenGL 4.1.
SYSTEM REQUIREMENTS:
Windows® 10, 11 or higher
64-bit OS required
2.0 GHz Intel Core i3 or higher
4 GB RAM or higher
1.6 GB free hard drive space or higher
OpenGL 4.1 supported graphics card required (1920x1080 recommended) **
Online connection required to perform online activation
Post by 570295535 »
You can try turning off OpenGL by changing it to:
"DisableAllOpenGL" "TRUE"
"OpenGLEnabled" "FALSE"
In this file:
C:\Users\Administrator\AppData\Roaming\Lost Marble\Moho Pro\14\Moho Pro14.user.settings
I'm from China, currently using: Moho 15 » Win10 System
:D :D :D :D :D :D :D :D :D :D :D
Kaniggelundzylinder
Post by Kaniggelundzylinder »
Its a Bug.
Delete all Point Colors and
the Surface will be back.
Now You can insert new Point Colors.
