How do i copy one layer from one moho project to another
vivekchakraverty
Post by vivekchakraverty »
How do i copy one layer from one moho project to another, I'm using moho 12.5
Re: How do i copy one layer from one moho project to another
Here's the direct method:
  1. Open both projects.
  2. In the first project, select the layers you wish to copy.
  3. Under Edit, choose Copy Layers.
  4. Go to the second project and select the layer where you want to paste the layer.
  5. Under Edit choose Paste Layer. The copied layers will be pasted above the selected layer.
Be sure to use Copy Layer and Paste Layer. This is a different set of commands from the standard Copy and Paste commands. Note that Copy Layer and Paste Layer also recognize Group layers, so you may not need to select every layer individually.
Another way is to use Import Moho Object. When you choose this method, Moho will let you choose which layers to import into the currently opened project, and there are additional options in this window if you need them.
vivekchakraverty
Sorry, for bothering you guys, got it!
