Mess on Frame 0
BrianLucas
Mess on Frame 0
Post by BrianLucas »
https://sageandmort.com/Mess.mp4
Please, can someone tells me why this happens on frame 0 and not on frame 1?
Thank you
Re: Mess on Frame 0
Frame 0 is the setup frame and it's not recommended for rig testing. Rig testing should be done on an animation frame (1 and higher.)
You can test some simple things on the setup frame, but, as you've discovered, it's not a reliable way to test complex rig setups, Smart Bone Actions, and Bone Targets.
A common way to test is to use the Design Mode command (Shift+Ctrl+D) to toggle between the chosen test/animation frame and the setup frame.
(Tip: I like to use my MQC button panel to toggle Design Mode...it's easier to access if you use a stylus.)
BrianLucas
Re: Mess on Frame 0
Thank you, Greenlaw.
